flabbet
1
- Added file presets - by @baj
- Greatly optimized startup times and performance of files with a lot of folders
- Removed Pen Mode (obsolete, not properly ported feature from V1.0)
- Improved render caching, panning the viewport around with whole document visible should be smoother
- It is now possible to import gif and APNG into frames
- Added adaptable properties to Switch Node. Additionally it can now be used with image (gpu) context (diamond sockets)
- Fixed duplicating shape when changing color - by @baj
- Fixed reference layer breaking undo - by @baj
- Opening SVG will now do a better job positioning nodes in the node graph
- Fixed several gradient rendering issues. Each gradient will now render in sRGB color space.
- Fixed various rendering bugs with nested layers
