Weird (soft?)lock
Not sure what I did, I only drew a line and it decided not to let me do anything on the canvas. But everything outside the canvas (and toolbar too I think) worked perfectly.
Do you remember what line did you create? Raster or vector?
And also what version did you use?
It was one diagonal line, and obviously, version 2.0.
I meant line from what toolset? There are 3 different type of toolsets: pixel art, painting and vector. Do you remember which one did you use?
And by version I mean exact version, the one written in bottom right
Vector I think? (My English isn’t Englishing) And it happened in the mentioned beta in the screenshot and every 2.0 beta before it.
I see, thanks for the info. I’ll look into it, if you have some reliable reproduction steps I would be really grateful (like a step by step checklist how to cause this deadlock)
Sure! I’ll get home and see.
