Closing with ‘File → Exit’ and the X button doesn’t help
Yeah, this is quite useful, I’ll take a look at it. But from the screenshot it looks like the crash happened when exporting a file?
its possible that i sent an older log in which i didnt allow pixieditor to export the file with protected folder access. there are lots of different logs i dont understand so i sent all unique ones i could find
also, it always loads the last autosave, i cant close files because ‘the last autosave’ always reopens them. to use pixieditor without my pc burning down, i have to delete all autosaves manually
ive searched all of event viewer and this problem isnt related to a crash at all, maybe pixieditor thinks it crashed because i closed it?
hmm, it shouldn’t. I’ll take a look at it
In 2.0.0.89 I changed behavior of autosave. When it’s disabled, it won’t reopen all files on unexpected shutdown
im gonna test it out the moment i arrive at home. thank you
