Troubleshooting Guide
PixiEditor doesn’t open / stopped opening
Switch to OpenGL
PixiEditor by default uses Vulkan to render graphics, some hardware and software may not properly work with it.
There are a few ways to do it.
If you’re using Standalone PixiEditor version:
Windows:
Right click on PixiEditor shortcut and select “Properties”, in “Target” add -–opengl after PixiEditor.exe and after the closing quote , for example “C:\Program Files\PixiEditor\PixiEditor.exe" --opengl)
Linux
Run binary with --opengl flag.
Example with Flatpak:
flatpak run net.pixieditor.PixiEditor --opengl
MacOS
MacOS always uses OpenGL
If you’re using Steam PixiEditor version:
  1. Right click on PixiEditor in the Library and click “Properties”
  2. In the Launch Options under the General tab, type --opengl
Another way to do it, is to locate local appdata of PixiEditor
Windows: Click Win + R and type %localappdata%/PixiEditor
linux: /home/yourusername/.local/share/PixiEditor
and creating a file called render_api.config and setting its contents to OpenGL
Making it pernament
If PixiEditor runs correctly, you can permanently set OpenGL as a default by going to Edit/Settings and set “Preferred Render Api” to “OpenGL”. After that, you won’t need to use --opengl flag anymore.
Check for zombie processes
Sometimes PixiEditor may not close properly and “Zombie” process appears. This only applies to Windows. Open Task Manager (Ctrl + Shift + Esc) and search for PixiEditor or PixiEditor.Desktop, if it exists, kill it and try opening PixiEditor again.
Run the app in Safe Mode
Windows:
Right click on PixiEditor shortcut and select “Properties”, in “Target” add -–safeMode after PixiEditor.exe and after the closing quote , for example “C:\Program Files\PixiEditor\PixiEditor.exe" --safeMode)
Linux
Run binary with --safeMode flag.
flatpak run net.pixieditor.PixiEditor --safeMode
MacOS
PixiEditor is likely installed under /Applications/PixiEditor.app or /Users/yourusername/Applications/PixiEditor.app (make sure to replace yourusername with your actual user name)
Run /Applications/PixiEditor.app/Contents/MacOS/PixiEditor -- --safeMode (make sure to include double --
  2. In the Launch Options under the General tab, type --safeMode
Clear app data
Installing and uninstalling the app does not remove preferences and local editor data. Sometimes it may cause issues, to fully reset PixiEditor you need to remove the following folders:
Windows
  • %localappdata%/PixiEditor then hit enter and remove the folder
  • %appdata%/PixiEditor then hit enter and remove the folder
  • %tmp%/PixiEditor then hit enter and remove the folder
macOS
Find and remove
  • /Users/yourusername/Library/Application Support/PixiEditor
  • $TMPDIR/PixiEditor
to find $TMPDIR, check https://superuser.com/questions/581347/where-is-the-temp-folder-in-os-x
Linux
Find and remove
  • /home/yourusername/.config/PixiEditor
  • /home/yourusername/.local/share/PixiEditor
  • /tmp/PixiEditor
In Flatpak version, paths are different, but uninstalling the app should automatically remove all associated files.
UI is shifted and does not match mouse clicks
Go to the Settings → Appearance and toggle on “Use system title bar” or pass --system-decorations CLI argument
PixiEditor opens but freezes
By default PixiEditor loads last files on startup, some files may cause PixiEditor to freeze.
Follow Run the app in Safe Mode guide under PixiEditor doesn't open / stopped opening above or Clear app data if it doesn’t help.
