Third Party Licenses button inside Help menu does nothing
The other options work as expected
Hey, what version do you have and where did you install PixiEditor from? Website or Steam?
Version 2.0.0.97 from the website, what should be the expected outcome, a window or a text? The other License button opens a text editor with the license.
It should open a folder containing all licenses. It is inside installation directory," Third Party Licenses". In my case, the path is C:\Program Files\PixiEditor\Third Party Licenses
If it doesn’t work, maybe there are some missing permissions or the folder is missing for some reason
