When assigning a shortcut to a command that is already used by a different command, a popup appears to confirm your choice.
However, this popup doesn’t prevent you from adding other keyboard shortcuts. The popup can be hidden behind the settings window.
In this example, the end result is:
- Use linear SRGB has no shortcut
- Use SRGB has the shortcut 4
- Use color 3 and 4 keep their old shortcuts (3 and 4)
It doesn’t seem like a huge deal but since it seems to be unintended behavior, fixing this may help prevent corrupted settings files.
