Procedural Particles Using Images Through the Shader Node
summon circle with procedural particles
summon circle custom fonts.pixi (494.2 KB)
The particles uses a custom shader that you can copy paste using the pixi file i provided. It is on top of the blue comment so it is easy to spot. The particles will always loop so using it as a sprite sheet wouldnt be a problem.
