Thank you to all contributors for helping with this release!
- Improved contrast of brush overlay - by flabbet
- Improved shift-click straight line drawing - by Equbuxu
- Scrolling over number inputs now requires focus, this prevents accidental changes - by flabbet
- Scrolling inside the timeline, now scrolls towards the active frame instead of mouse position - by flabbet
- Grid lines are now automatically 1/12 of the document size by default, instead of 1x1 px - by flabbet
- Trying to delete a layer when selection on the canvas is active, will now delete only canvas contents instead the entire layer - by flabbet
- Fixed Game of Life sample file - by Ghoti
- Fix Shift-clicking with the pixel-perfect brush setting renders the user unable to draw until the setting is disabled - by Equbuxu
- Fix Line tool ends are not consistently aligned with the mouse when using shift to lock to 45 - by Equbuxu
- Fix The beginning of the line is snapped to the corner of the pixel while the end of the line isn’t snapped at all - by Equbuxu
- Fixed layers in folders exporting duplicate SVG elements - by flabbet
- Fixed layer manager always scrolling to selected layer - by flabbet
- Fixed Find and Replace tool not working with 0 tolerance setting - by flabbet
- Fixed layer not creating when trying to draw on a folder without a mask - by flabbet
- Fixed an issue that required clicking twice to draw something on an automatically created layer - by flabbet
- Fixed a bug, that caused blurry viewport when it was rotated 90 or 180 degrees - by flabbet
- Fixed pasting an image into active layer not enabling editing overl
