PixiEditor 2.1.2.1
Available in 16 581 375 colors!
  • Added Comment Node - by Ghoti
It is now possible to create custom colored zones with a comment text.
  • Added Find and Replace tool to Adjustments toolset - by Ghoti
  • Added Swap Color tool to Adjustments toolset - by Laxan
  • Added Background eraser tool to Adjustments toolset - by Laxan
  • Added Gradient Brush - by AwsomeAnthony
  • Added more sample texture options in Stroke Info Node - by flabbet
  • Added reset symmetry line buttons - by Spencer A
  • Added Stamp property to Stroke Info Node - by flabbet
  • Added Color Mapping Node and palette input type - by Ghoti
  • Added Random Node - by flabbet
  • Added Normalize Color Values to Separate and Combine Color Nodes - by flabbet
  • Added Palette and Decompose Palette Nodes - by Ghoti
  • Selecting multiple vector layers and changing main color will now recolor all layers - by flabbet
  • Various optimizations for the Brush Engine - by flabbet
  • Improved localization debug window - by Equbuxu
  • Improved Swap Color tool and optimized its performance - by Laxan3000
  • Added velocity interpolation for faster strokes - by flabbet
  • Optimized Gradient tool performance - by flabbet
  • Added more blend modes to Merge Node - by flabbet
  • Colors in the Node Graph now use 0-1 range instead of 0-255 - by Equbuxu and flabbet
  • Translated 100% of the app to Spanish - by Matalya
  • Fixed not being able to move layers when there was non-structure layer in between - by flabbet
  • Fixed a bug that caused new layer to create when multiple layers were selected and user clicked on the canvas - by flabbet
  • It is now possible to use Open from clipboard option when no document is opened - by flabbet
  • Fixed layer order reversing when dragging multiple layers on the very bottom of the layer list - by flabbet
  • Fixed creating array of arrays - by Ghoti
  • Fixed auto-saves saving to temp folder instead of local app data folder - by flabbet
  • Debug recording graph will now save snapshot to temp folder instead current working directory - by flabbet
  • Fixed deleting a folder not deleting all nested folders - by flabbet
  • Added a guard to prevent crash when corrupted font is installed - by flabbet
  • Fixed various crashes when working with text - by flabbet
  • Fixed HSL and HSV modes not working for Separate and Combine Color Nodes - by Equbuxu and flabbet
  • Fixed various crashes - by flabbet
