2.1.1.5
- Added “Game Of Life” example file
- Added Slovenian language - by Andrew Poženel
- Added Blending Paint Brush - by Ghoti
- Moved Autosaves location to local appdata
- Added Minor optimization for brushes with cached stamps
- Fixed an exception happening when using Modify Image zone - by Ghoti
- Fixed parsing invalid svg filter link
- Fixed a crash when connecting number to math mode socket
- Fixed a crash related to invalid file extension
- Fixed a bug which caused animation timer to divide by 0
- Fixed long filename bug with discord rich presence
- Fixed a case where app was unable to save as .pixi
- Fixed a crash when pasting an image to a frame without a cel
- Fixed node picker navigation bug (clicking on categories will bring the view to correct position)
- Fixed a case that required uninstalling extension twice to remove it
- Fixed various crash scenarios
