PixiEditor 2.1.1.5-dev
2.1.1.5-dev
  • Added “Game Of Life” example file
  • Added Slovenian language - by Andrew Poženel
  • Added Blending Paint Brush - by Ghoti
  • Moved Autosaves location to local appdata
  • Added Minor optimization for brushes with cached stamps
  • Fixed an exception happening when using Modify Image zone - by Ghoti
  • Fixed parsing invalid svg filter link
  • Fixed a crash when connecting number to math mode socket
  • Fixed a crash related to invalid file extension
  • Fixed a bug which caused animation timer to divide by 0
  • Fixed long filename bug with discord rich presence
  • Fixed a case where app was unable to save as .pixi
  • Fixed a crash when pasting an image to a frame without a cel
  • Fixed node picker navigation bug (clicking on categories will bring the view to correct position)
  • Fixed a case that required uninstalling extension twice to remove it
  • Fixed various crash scenarios
