PixiEditor 2.1.1.4
2.1.1.4
  • Added a dialog asking before overwriting non .pixi files
  • Added color picker tool overlay (by Artem Melnyk)
  • Added new toolset “Adjustments” with Blur Tool, Sharpen Tool, Smudge Tool and Brightness Tool
  • Added Velocity Output to Stroke Info Node
  • Added “Place Element” to file paths in the command search (by CPK)
  • Added Oversample input in Brush Output Node,
  • Added Sample Size output to Stroke Info Node
  • [ABI] Added an option to pass config to custom tools
  • Improved Brightness tool, it now supports custom brushes as brightness masks.
  • Improved UI of Extension Browser
  • Improved the UI of extensions button in the tools picker
  • Added a button in the top menu bar for easier access to the Extension Browser
  • Changed the icons of the extensions buttons
  • Replaced Founder’s Pack onboarding step with featured extensions
  • Fixed binding key modifiers as a single key (e.g. Ctrl, Shift, Alt) not working.
  • Fixed undo/redo with single key shortcut triggering when typed with text tool
  • Fixed an issue with preview scaling for different window sizes
  • Fixed brush shape overlay not updating in some cases
  • Fixed an issue with brush settings resetting on tool change and not synchronizing properly
  • Fixed invalid previews for some nodes
  • Fixed a crash when trying to open .svg file as reference layer
  • Fixed non-scrollable tools picker
  • Fixed a bug that caused some tools to become the pen tool with Shared Toolbar option enabled
  • As always, fixed various crashes
