PixiEditor 2.1.0.14-dev
  • Added UI scaling option
  • Added Target Sample Texture Pos to Stroke Info Node
  • Added Disallow Auto Scaling input to Create Image Node
  • Combine Color Node in GPU context will now use 0-255 range instead of 0-1 when manually typing colors. Internally it still uses 0-1
  • Manually creating a layer node in the Node Graph will now not select it automatically in the layers panel
  • Fixed animation rendering error on macOS
  • Improved CreateImageNode chunk scaling
  • Improved visible region precision
  • Fixed tile node scaling
  • Fixed layer scaling wrong on zoom out in some cases
  • Pixel art eraser will now use pixel circle by default
  • Added gradient tool tooltip
  • Fixed cel previews not refreshing and framerate not cloning to smart layer
  • Fixed Nested Documet Node document picker UI
  • Made gif a default option for exporting animation
  • Optimized selecting brush options
  • Using brushes in pixel art toolset will now disable anti-aliasing for most brushes
  • Fixed various crashes
