This is a bug report. Palette color swatches appear in the Palette Browser, but are not visible in the docker on the right side of the application after the palette has been chosen. I just see a symbol that looks like a >. I’m using the version 2.0.0.28 Beta on Windows 10 Home 22H2.
Yes, it happens with gpl palettes that I’ve downloaded from Lospec. Yes, if I open a new project, then use Add primary color to palette then a single > appears in palette docker.
