More Shape Primitives
It’d be cool to see more shape primitives and shape options akin to something like affinity designer. (e.g. star, semi-circle, ring, crescent moon, circle segment, tear drop, chat square…etc.) Affinity has all of these and more as well as edit options for quick tweaks to each kind of shape.
For instance, with the ring tool, you can set the inner and outer radius separately. With the crescent tool, the size of the crescent (e.g. waning, gibbous …etc) can be set with a simple handle as well. Additionally, the star tool allows for determining the number of points and the inner and outer radius.
Having more primitives will allow artists to jump into an idea more quickly without having to resort to boolean operations to build up shapes they can then work with.
I see there is a request in for a shape builder feature and that would be cool as well but having primitives to just “grab off the shelf” will definitely improve artist workflow and increase artist output.
Video demonstration of what I’m referring to:
