Steam version on linux is broken
Would you mind sharing more details? Your specs, desktop environment (looks like Hyprland?), render api etc.
Go to settings and change render api to “OpenGL”
I’m using Hyprland with a ‘newer’ Intel GPU
Changing the render API to OpenGL didn’t change anything
When I built the project from source, it worked fine
I’m also currently testing Avalonia, because I still can’t use copy/cut/paste
Also, the issue with the blank canvas came up recently
It worked before just fine
It’s probably because I built a version from source
