Export zones (more export options)
Currently, we only can export the whole canva.
It would be amazing to personalize the zone to export, and have a few presets like:
Inspired from Inkscape
I’ll be adding this. In the next update it’ll be only doable via Node Graph, which will allow for defining your own export zones, but presets in the export menu is also something that eventually land into the app.
Starting version 2.0.0.85 it is now possible to export custom zones. It requires a little bit of setup but it’s quite flexible.
