Crash found! -.-.-.-
i clicked on a color in the color palette tab
crash report:
crash-2025-05-22_19-20-45_534.zip (6.4 KB)
@flabbet
if you remember the broken autosave and ‘crashes’ i was getting, it actually helped me recover my files!
im completely confused because it said ‘2 Files might be unrecoverable’, but i still got them back
This is a serious bug, thanks!
This is what the autosave is for! Glad it helped.
The problem is, i left autosaves off…
they are disabled and still work
Well autosave system always works (or at least tries as hard as it can) in case of crashes and unexpected shutdowns, no matter if you disable it, so this is what is probably happening. But regarding your previous issue, does it reopen all files on each startup still?
yes, it still reopens all files, but i havent updated since yesterday, maybe the new update fixes it
