Clipboard on Wayland (Hyprland) doesn't work
Trying to copy/cut/paste would result in nothing
Just silence
It seems like the program responds, but it wont modify the canvas
I tried:
  • Changing proton versions
  • Allowing clipboard access (there is no such thing, apps always have access)
  • Building from source
More specific description:
When starting up the program, you have a few seconds where you can freely use the tools normally (copy/cut/paste), but after those few seconds are over, the program stops doing anything with the clipboard
Edit: After further testing, I’ve noticed that selection in general doesn’t seem to work properly (selecting and pressing delete doesn’t work)
Did you build/test latest 2.1.0.6-dev version? In 2.1x clipboard got a little rework and should work as expected.
Same issue
I can copy and paste twice before it stops working
