Changelogs 2.1.0.9-dev
  • Added option to toggle system decorations under “Appearance” tab
  • Disabled toggle alpha lock button on layer’s that are not compatible (Vector, Nested)
  • Viewport now does not recenter each time you change the tab
  • Fixed not being able to use color picker with Left Alt
  • Fixed laggy toolset switching
  • Fixed name overlapping in Nested Node on pick document button
  • Fixed not being able to click on font picker in the node graph (also added a color to socket)
  • Fixed default font value not visible in the node graph
  • Fixed drawing bug that was caused by drawing on two different documents side by side
I have some issues with Steam, so update there might be a little later
