Changelog 2.1.1.6-dev
2.1.1.6
Date: 18.06.2026
Available in 16 581 375 colors!
  • Added Comment Node - by Ghoti
It is now possible to create custom colored zones with a comment text.
  • Added Find and Replace tool to Adjustments toolset - by Ghoti
  • Added Swap Color tool to Adjustments toolset - by Laxan
  • Added Gradient Brush - by AwsomeAnthony
  • Selecting multiple vector layers and changing main color will now recolor all layers - by flabbet
  • Various optimizations for the Brush Engine - by flabbet
  • Improved localization debug window - by Equbuxu
  • Fixed not being able to move layers when there was non-structure layer in between - by flabbet
  • Fixed a bug that caused new layer to create when multiple layers were selected and user clicked on the canvas - by flabbet
  • It is now possible to use Open from clipboard option when no document is opened - by flabbet
  • Fixed layer order reversing when dragging multiple layers on the very bottom of the layer list - by flabbet
