flabbet
1
Changes
- Vector shapes now have transformation overlay around their geometry, not visual bounds
- Fixed selecting vector shapes on tap
- Fixed Line tool in painting mode doesn’t work correctly with symmetry, same with rectangle radius
- Fixed center active viewport command
- Fixed duplicating folder breaking timeline
- Fixed resize and then undo applying one frame to all key frames
- Fixed cel duration and visibility not duplicating on layer duplicate
- Fixed logo being flipped on right-to-left layout
- Fixed shapes aren’t created if the start point is left top corner of the canvas
- Fixed Rectangle not saving radius for .svg file
- Fixed Rectangle Stroke not covering the whole shape when using big radius
- Fixed crash reconnecting nodes in the Node Graph
- Fixed cutting and then pasting selected area
- Fixed shape shortcuts switching to vector on any toolset
