This changelog is for development version only
- Vector Object Selection Doesn’t Work As Expected [BUG]: Vector Object Selection Doesn't Work As Expected · Issue #1137 · PixiEditor/PixiEditor · GitHub
- Fixed Line tool in painting mode doesn’t work correctly with symmetry, same with rectangle radius [BUG]: Line tool in painting mode doesn't work correctly with symmetry · Issue #1171 · PixiEditor/PixiEditor · GitHub
- Fixed center active viewport command
- Fixed duplicating folder breaks timeline once again
- Fixed resize and then undo applying one frame to all key frames
- Fixed cel duration and visibility not duplicating on layer duplicate
- Fixed logo being flipped on right-to-left layout
