Breaking changes
- Sample Image node by default now uses normalized coordinates
- Added Normalize Coordinates option to Modify Image and Sample Image Nodes.
- Added Compose and Decompose Matrix nodes
- Added Position to Transform Node
- It is now possible to copy-paste nodes between documents
- Matrix nodes now work in GPU context (diamond sockets)
- Removed auto premultiplicating opacity in Modify Image Node to avoid double-premultiplication
- Fixed case sensitive extensions crash
- Fixed quiet crashes for some cases (async methods thorwing exception)
- Fixed undoing transform overlay when no movement was made
- Fixed License, FFmpeg and no-updates file lookup to be in binary directory instead of working directory
- Fixed missing cels recovery on opening .pixi
- Fixed transform matrices inputted to Shader node not being passed in colum major order
- Fixed symmetry icon and tooltip in viewport options
- Fixed issues with selection nodes with selection rectangle
- Fixed dragging timeline cels
