- Added Remap Node
- Added Evaulate Path Node
- Added path offset to Text on Path node
- To zoom a timeline, now you need to hold shift or scroll directly on the tick bar on top
- Clicking and dragging with text tool now changes the font size until releasing mouse
- Clicking and dragging with vector path tool now creates continous splines
- Added Open from clipboard to File menu
- Hitting Space in graph view now opens node picker
- Control points in vector path overlay are now only displayed for selected points
- Fixed parsing some and SVG tags
- Fixed a bug that caused vector shapes to be aligned to pixels when scaling
- Fixed issues when transforming some vector shapes
- Fixed overflowing action display text
- Exporting animation now properly exports from first frame to duration
- Fixed animation duration not updating
- Fixed dragging edge of the cel being offseted
- Fixed scrolling timeline affecting zoom
- Normalized time in Time node now is exactly 0 at first frame and 1 and last
- Fixed bugs related to rendering with Create Image Node and Shader Node
- Fixed having to hit CTRL + V twice to paste
- Fixed not being able to drag transform of pasted image, when move viewport tool is selected
- Fixed self snapping issue in path overlay
