- Added safe mode which doesn’t load extensions nor last session files on start. It can be enabled using
--safeMode launch argument or in crash dialog.
- Added Open autosave folder command
- Blue selection fill now doesn’t show when using tools other than selection tools.
- Remove close points node now doesn’t remove points if distance is set to 0
- Added safe check for deserializing older files. Prevents a crash
- Fixed copy pasting images between documents
- Fixed deleting cels from duplicated layer
- Fixed self snapping when using shape tools on layers inside folders
- Fixed vector line tool snapping wrong when holding shift.
- Fixed snap lines and distance wrong when drawing a vector line.
- Fixed .deb shell script not being executable
