- Fixed hard crash that happened randomly
idk how to get the beta to try it but im new here so ya
You can download the app on steam https://store.steampowered.com/app/2218560/PixiEditor__Pixel_Art_Editor/
After you download, right click the app in your library, go to properties, open the Betas section and opt into beta versions there
Alternatively, you can download the latest build from github Releases · PixiEditor/PixiEditor-development-channel · GitHub
Also alternatively, I believe you can also just download the normal installer from https://pixieditor.net, install and launch the app, open settings and choose the development update channel there. The app should then auto-update to the latest beta version
Thank you but i rather wait i mean im still using the orginal but i’llw ait my computer says its unsafe which i know its safe but i’ll jsut wait ![]()
