Changelog 2.0.0.49
  • Added color node. Hooking it to modify image nodes ensures that color gets converted to proper color space automatically.
Changes
  • Changed dragging logic for tabs, so it is more suitable for other operating systems
  • Changed rendering logic of previews. It should be more stable now
Bug fixes
  • Fixed a bug that caused focus not to return to viewport when closing search window with ESC
  • Fixed a bug that caused reference layer to not recognize pixel format and display colors wrong
  • Fixed crash when deleting nodes
  • Fixed shortcuts not being visible when recovering from crash
  • Fixed a bug that caused some animation data not load
  • Fixed a bug that made selecting other layers with pressing on canvas almost impossible
