- Fixed gamma blending, now all image processing is done in linear color space, instead of srgb. This greatly improves blending color accuracy. The new blending might result in undesired look for all existing files, so all pre 2.0.0.32 files will not have it enabled!
To manually convert your file to new blending, go to search bar in the top (or click Ctrl + K) and select "Convert document using legacy blending mode to linear sRGB)
All new files will have it enabled by default and it can’t be changed.
