Change system font
Hi, I just installed PixiEditor. When I open the app, the system font is simply just not readable. How can I change the default system font so that I can read the menu properly
If you are using the Steam version, you can download the latest version from “development” channel (right click on game > Version & Betas > Development).
Then, go to “Edit > Settings > Accesibility“, and you can change the text & icons size :slight_smile:
Here’s a screenshot of the scaled UI (the settings window is the only one that doesn’t scale, but that’s intentionally made to avoid certain problems)
Oh, sorry, I didn’t realize that you wanted to change the font and not the size :folded_hands:
What operating system are you using?
I’m sorry… I am indeed using the desktop version, not the stream version. From the About screen, I amd using Version 2.0.11 Release Wild.
I don’t see an “Accessibility” option in Edit>Settings.
I’m using Ubuntu 22.04.5 LTS
Hmm, I’m afraid it can only be fixed by tweaking system settings. PixiEditor doesn’t have a way to change it. Do you get this issue on other apps as well?
