Canvas/images not appearing?
The canvas does not appear when I create new, try example files, or open file. I cannot draw, I can’t even see the canvas.
The sample pictures don’t load either. I’m very sorry to bother, but is there a setting that could be causing this?
Try changing Render API in the settings. You likely have vulkan selected, so switch to OpenGL
I changed it to OpenGL, but it is still unfortunately not appearing
What operating system are you on and what is your GPU?
Make sure to update graphics drivers to the latest version. If you are using Linux and have Nvidia GPU, you may need to use proprietary drivers instead of nouveau
I’m very sorry by how late my reply is, but my OS is Windows 10, and my graphics are an Intel(R) HD Graphics 4600.
