Beta not updating
On the Development stream, I noticed that since 2.0.0.70, it’s no longer checking for updates on launch. Before this, it worked fine. I decided to reinstall and that gave me the initial update to the latest dev release, but that’s all. I’m currently on 2.0.0.73. Thank you!
We’ve changed updating behavior, so it doesn’t silently update, maybe it’s not obvious enough though, but now if an update is available, you’ll see this exclamation mark in top left corner on the logo
You need to click it and and press “Download” after it downloads the update, you’ll see a blue dot there, after you click it, you’ll be able to switch to a new version, or it will happen automatically on close.
I’m sorry. I did see something posted about changes to updates but I glossed over it. Thank you. Anyway, I like the changes to updating.
