Add Mask to Apply Filter
A Mask Input for the Apply Filter Node would be nice and make sense in my opinion
Would simplify this Node Setup
Could also include a option to invert the Mask
I kind of disagree, why would there be a mask input in Apply Filter?
In my opinion it would imply that mask will affect where filter is applied
That is actually exactly what I meant, I just worded it wrong and wasn’t able to post the whole Node Graph
So the Mask Input would specify where the Filter is applied
Which would remove the need for the Mask and Merge need in the Graph below
I see yeah, that makes sense
