2.2.0.3
Date: 21.10.2026
- Scrolling over number inputs now require focus
- Fixed crash when opening a login popup
- Fixed layer manager always scrolling to newly selected layer
- Fixed tool not drawing immediately on newly created layer when it was started on incompatible layer
- Fixed find and replace tool with 0 tolerance setting
2.2.0.2
Date: 20.10.2026
- Reworked text editing, it is now possible to select a part of the text and edit its settings directly
- Reworked font picker UI
- Added favourite fonts filtering
- Pen tool shift key straight line overlay and snapping
- Undo/redo support for straight line drawing
- Fixed a crash when dragging layers on macOS
- Fixed not working drag and drop of palette colors
- Fix brush engine snap to pixels for negative coordinates
- Fixed folder not rendering in high dpi when the opacity is < 100%
- Fixed duplicate svg tags when exporting content with folders
