2.0.0.71 Changelog
  • Added a possibility to move multiple layers at once in layers view
  • Creating a new folder when multiple layers are selected will now put them inside
  • Improved no documents ui
  • Added a ability to change tool size with ctrl + scroll
  • Layers view now scrolls automatically if you drag layers to top or bottom border
  • Fixed dropping images on layers view when it was full
  • Fixed renaming folder no working with double click sometimes
  • Fixed double click to rename collapse/open folder
  • Fixed collapsed reference layer not freeing space for layers
  • Fixed animation cels constantly repainting, which caused lags on bigger animations
  • Fixed color picker not updating hex value in dropdown pickers
