2.0.0.68 Changelog
  • Added an option to configure grid lines size
  • Added an option to disable opening folder when exporting
  • Added delete selected elements with “Delete”
  • Disabled snapping for invisible layers
  • Brightness tool now works better with fast mouse movements
  • Improved snapping overlay, now it displays what it snaps to and distance to it
  • Improved merging vector shapes together
  • Improved High DPI vector layers rendering in various scenarios such as clipping, masks, custom blend modes and in folders
  • Improved caret visibility in text tool
  • Fixed transform being stuck at 0,0
  • Fixed a self snapping issue, that caused jittering
  • Fixed snapping not work when placing vector point
  • Fixed disappearing image when transforming perspective
  • Fixed not being able to use PixiEditor when clicking “No” in Windows UAC during update
  • Fixed undo/redo buttons being always disabled
  • Fixed loading documents with clip to below not updating this value properly
  • Fixed canvas not updating on content changes
  • Fixed drawing on masks on vector layers
  • Fixed changing colors when rendering emojis on different zooms
  • Fixed duplicating layers not duplicate animation
  • Fixed vector layers not scale when resizing image
  • Fixed viewport not recenter when changing resizing canvas
  • Fixed being able to loop nodes with layers view
  • Fixed a bug that disallowed saving when font was empty in Text Node
  • Fixed nodes localization
  • Fixed localization in dropdowns in nodes
  • Invisible layers in animation data now is not taken into consideration when exporting
  • Fixed not being able to interact with timeline stuff using digital pen
