2.0.0.39-dev changelog
  • Added copy visible option (Edit → Copy visible) or with SHIFT + C
  • Added sample mode to Sample Image and Modify Image nodes
Changes
  • Changed copy color shortcut from Shift + C to Shift + Alt + C
  • Creating new cel will now create it in the first empty frame starting at animation cursor position
  • Move viewport tool can now be quickly accesed with spacebar
  • Fixed copy-pasting vectors
  • Fixed infinite undo loop in move tool
  • Fixed color space correction during exporting
  • Fixed color space correction in previews
  • Fixed onion skin displaying default frame when last frame is active
  • Fixed a bug that caused shortcuts not to work sometimes
  • Fixed a bug that caused restoring wrong tool when using transient tool (such as move viewport)
  • Fixed a bug that caused merging layers not apply clipping to previous member
  • Fixed a case that caused a hard crash (not recoverable) in random moments
