What i mean with this is to make a window (instead of just a button) like FireAlpaca’s that allows you to save and use different brush profiles that have options like “pixelart brush”, “size 20px”, “custom pressure curve” or stuff like that, it could be added as an option in the preference settings.
While I understand where are you coming from, the approach in PixiEditor is a little different.
Because you have a possibility to duplicate and edit basically any brush, this is a way to go for creating variations of a Brush.
Try duplicating any brush, going into the graph and hard coding the size of 20 instead of binding it to a tool size. Assigning custom tags is also a way to organize things.
The only limitation I see, is the fact, that when you hard code the value, you won’t be able to change it, but I suppose the purpose of presets is to have a single value out of the box right?
yeah, as i said, i’d love to be able to replicate my firealpaca workflow right into the app! :3
