This is a changelog between dev version 2.1.1.6 and 2.1.2.0.
- Added more sample texture options in Stroke Info Node - by flabbet
- Added reset symmetry line buttons - by Spencer A
- Added Stamp property to Stroke Info Node - by flabbet
- Added Color Mapping Node and palette input type - by Ghoti
- Added Random Node - by flabbet
- Added Normalize Color Values to Separate and Combine Color Nodes - by flabbet
- Added Palette and Decompose Palette Nodes - by Ghoti
- Improved Swap Color tool and optimized its performance - by Laxan3000
- Added velocity interpolation for faster strokes - by flabbet
- Optimized Gradient tool performance - by flabbet
- Added more blend modes to Merge Node - by flabbet
- Colors in the Node Graph now use 0-1 range instead of 0-255 - by Equbuxu and flabbet
- Optimized drawing performance with iterative rendering - by flabbet
- Translated 100% of the app to Spanish - by Matalya
- Fixed creating array of arrays - by Ghoti
- Fixed auto-saves saving to temp folder instead of local app data folder - by flabbet
- Fixed Vector Math Node copy pasting normal Math Node - by flabbet
- Debug recording graph will now save snapshot to temp folder instead current working directory - by flabbet
- Fixed deleting a folder not deleting all nested folders - by flabbet
- Added a guard to prevent crash when corrupted font is installed - by flabbet
- Fixed various crashes when working with text - by flabbet
- Fixed HSL and HSV modes not working for Separate and Combine Color Nodes - by Equbuxu and flabbet
- Fixed various crashes - by flabbet
